Results 1 to 10 of 14
Thread: VR6 - Reliable daily? (First car)
    May 2011
    Hi everyone,
    I'm looking to get my first car, and the VR6 is top of the list at the moment. My only question is, assuming regular maintenance and servicing, is it a reliable car?
    I've read about various gremlins (window units, heater core) and expensive wear n tear (timing chains), these don't concern me. I can live with having the window up and putting a jumper on.
    I simply want to know is the car going to be able to get me where I need to go, when I need to be there.
    The car I'm most interested in atm has 263k km, so the engines ability to last and still be reliable is what I'm most curious about.
    Thanks for the help!
    (Sorry if this has been covered a billion times.. I tried searching but didn't get much of anything back.)
    Apr 2011
    I just borrowed my partners dads VR6 about 3 weeks ago, with the view to purchase. It has been great to drive, it has 280xxx kms on it as well, and hasnt faulted.
    96 VW VR6 Golf (Daily driver)
    65 VW Beetle (Under restoration)
    Feb 2010
    so far out of the 3 mk3s ive had. only one was a lemon. i think its more like a lucky dip. mk3s have same problems.
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Feb 2008
    mOOROOLBARK
    it will be reliable if its been looked after!
    if not........... (short answer) ''it will cost you a lot of money''
    Aug 2008
    Kensington, Sydney
    Quote Originally Posted by DUB84 View Post
    Pretty much agree with that, it's based more on luck than anything else! When I bought mine just under two years ago it had fk-all mileage on it (95,200km) which I thought was a godsend, but it gradually turned into a bitsamissin affair and I've replaced practically all of it. I've never broken down or been left stranded for any reason other than my own stupidity though (lol @ running out of fuel. Twice.), the engine is perfect and has never given me trouble... It's only ABSOLUTELY EVERYTHING ELSE that cocks up.
    Sep 2009
    Mines been trouble free for almost a year (wow times goes fast :O)
    actually thats a lie. Ive had numerous problems. All of which where my own fault though, such as fiddling with coolant hoses to try and tidy the engine bay up, destroyed oil pump and pan from being too low, ect ect. Look after it and itll be fine Parts are cheap to fix em up from the US, and even though its a bit tight in there (one of the best quotes I read, yet cant remember properly, was along the lines of: you have to pay something to fit 10pounds of crap in a bag made for 5) with a bit of research and hard work you can probably swap everything yourself as it break
    I doubt theres any cars of this age which arent going to give you problems
    Jun 2007
    Eastern Suburbs Melbourne
    You've already mentioned the couple big things that go wrong with VR's, apart from that, they're generally trouble free.
    Providing you get one that's been cared for, or get one that needs TLC (and give it the TLC, obviously) you should have a perfectly fine, trouble free car.
    Mk 3's were the last of the robust golfs. Just don't get an auto,
    i like volkswagens
    Sep 2009
    Oh yeah. its probably less painful to just set fire to your wallet then it is to own an auto.
    Jul 2010
    qld
    if something does muck up theres so much info on how to fix it and any of us on here ill be happy to help as much as we can plus owning a mk3 has been a massive learning curve for me,
    Radiators are over rated
    Gosford Central Coast NSW
    one thing with mk3's is that they really are built well in the first place - the trouble with that is they can creep into high km's without anyone doing any proper maintenance on them, then all of a sudden BAM you are doing something every weekend on it (which, for a first car, is a good way to learn your way about the car).
    i also bought my mk3 with lowish km (131k) but because I drive a lot I too have replaced almost everything that is a serviceable item, and some things that arent aswell (but i've put 146,000km on it and its only let me down once, and that was part of a gearbox saga very A-typical of mk3's).
    if I were you i'd look at a 4 cylinder one though - just because when you're young, you don't really need to own a money pit like a vr6.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
