According to Bently's:
The three plugs from left to right are:
1. After-run coolant fan control thermal switch (F87) and ECT sensor (G2).
2. Engine Cooland Temperature (ECT) sensor (G62).
3. A/C Cutout thermal switch (F163) and third speed coolant fan control thermal switch (F165)
1. Should control the thermo fans and the thermostat after the engine is stopped (or while it's on).
2. Sends the temp to the guage / ECU.
3. Should work with the AC to turn on the thermo fans when the AC is on. (or when the car is hot)
