Results 1 to 4 of 4
Thread: VR6 power Windows issue
    Jun 2012
    Guys,my driver side window stopped working,I opened the door cover,the cable was off the track,looks hard to fix,still trying,the regulator is working fine,the fuse box all good,the thing is that all windows not working now!! Any ideas ?
    Mar 2012
    Central Coast, NSW
    Welcome to mk3 power windows my back right stopped working one day pulled it apart to have a look thinking I would need to fix the regulator just mucked around with the plugs and all worked fine again. So my advice is just double check all your grounds and make sure everything is plugged in properly. Weird that they all stopped though.
    Jul 2012
    Boronia
    Iv custom mod'd all of my regulators, the problem is that theres too much plastic.
    The clamp that holds that glass is held to the cable with plastic (i made a little metal plate and riveted it on. and the cable stoppers at the top and bottom are plastic. .. take the whole lot out, and spend some time at the work bench
    VR6 AAA
    'Another Awesome Achiever'
    Jun 2012
    Looks like my wife will burn my VR6 this weekend also
