Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: vr6 pcv valve
    Sep 2009
    Auckland, NZ
    You can get the PCV valve separately from the the dealer if you use the one for the Sharan. Only thing is I'm not 100% sure if the PCV valve is exactly same as the mk3 golf VR6. It's still expensive, $137 NZD, but better than $300+ for the PCV and intake.
    What were the measurement/specs for the oil breather & how did you block off the other lines?
    Aug 2012
    Kangaroo Valley, NSW
    vr6 pcv valve
    Holy thread revival Batman!
    Jul 2009
    i did the breather fix and I think it was 20mm in diameter. but I got rid of it quick because the fumes would go straight through my vents and kill me inside everytime I stopped at the lights.
    '94 3dr vr6
    Jan 2013
    Redfern, NSW
    So I'm in the same situation now. Quite frustrating re having to buy the whole intake section. Barloworld said they'd do it for $260 but that's still a lot for parts I don't need. (See pic below). Has anyone done a DIY oil catch can? Is that a logical solution to the problem or just as expensive?
    Jun 2011
    vr6 pcv valve
    Rubber hose for $2.00
    "I only post on Facebook if I know i am going to get likes" - M
    Mar 2012
    Central Coast, NSW
    vr6 pcv valve
    I currently have some hose straight from the crankcase to intake just means oil residue in the throttle body like mentioned earlier. Looking into doing a catch can soon. Super easy, just gotta find a nice place to mount it.
