I agree. There's no excuse for poor design in a car with the breeding of a VR6. Plastic water pump impeller! :roll: I wouldn't sweat about not having removed the smaller bits of plastic from an old Golf or Passat cooling system as the tubes in the radiator are of a large diameter, but I don't know about the VR6. I used to install a plastic cone-shaped filter in the top hose of any car that I had worked on and had used silicone on cooling system gaskets. It was available from the RAC and it caught a scary amount of silicone and Al oxide lumps coursing around the cooling system. If you can still get them it should be worth the $4.
