Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: VR6 Low oil and engine clicking
    Dec 2006
    Kilsyth, VIC
    According to the manual, oil use of up to 1L / 1000km is "normal". The VR6's do run hot and mine always seemed to burn off some oil so I always checked it when putting in fuel and topped up a little every now and again.
    ...mind you, since the whole system takes 5L to fill, 4L is on the pretty extreme side of things... (but theoretically possible after only 4,000km)...
    Jun 2011
    Quote Originally Posted by whiteVR6 View Post
    Hydraulic tensioners dont break, the spring tension just decreases against the timing chain. If it was broken you'd have the timing chain jumping teeth on the cam gear.
    I used the word break for easy understanding. It was scorched which when the oil was thinner managed to release the tension.
