um,,,remember when u didnt change the oil when it was time??? well,,,,payback is a bit@%...............lol
Latly my VR6 has been playing up and losing power after it had been sitting idleing at the traffic lights. After strugling through the power loss, i back off and let the car idle, and it clears up and goes as well as ever. WHATS GOING ON!! This is giving me the ****s.
no, surely it can't be user abuse..........
Mate you need a scan on your ecu mate to check your sensors. First port of call. Air/fuel ratio problem by the sounds
Alba European
Have you got the A/C on? It's been bloody hot these days.
Did you change the oil and get it serviced yet?
compression tests are easy to do, i always try to do them when ever i have the plugs out. sounds like it could be a bad fuel pickup, maybe your pump filter in the tank is blocked , so it will only pump a small amount of fuel. and when you nail it it gets used , they when you back off the fuel pump catches up. worth thinking about.
cheers brenton
MK1 4door
MK2VR6
MK3VR6
Transporter
and untold wrecks
I'll bring my laptop and Vagcom to the cruise and scan it for you mate.
VAGCOm to the rescue!!!!! Fuel pressure gauge,vac gauge, compression gauge best tools in the kit hey!!
Good luck
Alba European
