Results 1 to 6 of 6
Thread: VR6 intermittent cut out on starting - any suggestions?
    Oct 2005
    i've had this problem for a few years on my 95 vr6 and never solved the problem.
    car starts normally but then after about 2 seconds of running, cuts out immeditately and almost instantaneously - like there is no fuel. happens intermittently but can't predict when it will occur. sometimes takes 6-8 goes at starting up before engine stays running.
    opening the throttle before ignition sometimes helps.
    no other problems once it goes. took it to a dealer a while back but of course couldn't replicate behaviour.
    any advice?
    \'95 Golf VR6
    20v kit car Guest
    the problem is the reader coil for the imobilizer..if you have a spare key use it as the magnetic code may be a bit better condition than the high use key...a dealer will be able to either recode the 2 keys and replace the readercoil as it comes up as a hard fault on the test vas system....try and remove the key and reinsert it the next time the prob happens...hope this sheds some light on the prob and cure cheers steve
    Golfwise Guest
    Well done Kit that sounds like good info.I'll be putting that one in the memory bank.
    Oct 2005
    yippee! seems to have done the job - remove and re-insert the key - simplest and cheapest fix ever (it has only happened 3 times since the first post, but each time the second key insert has worked! - so i will take that as a good trend....
    thanks for the information!!!!
    \'95 Golf VR6
    imported_brackie Guest
    Another satisfied user
    Thanks, 20v kit car! That's what this forum is all about!
    Oct 2005
    well.... it had to prove me wrong....
    it happened again but the key-reinsertion didn't work this time!
    after about 10 goes at it (key in and out), it finally stayed on
    the car must have been reading my thoughts - i was thinking just the day before it happened that i should rewire the kill switch which i took off a few years ago because i thought that may be the problem.
    Maybe it is the key - and maybe needs a good hit to whack it back into shape!
    \'95 Golf VR6
Similar Threads
  1. MK3 muffler suggestions
    By wayz in forum Mk3 Golf & Vento
    Last Post: 01-12-2006, 06:26 PM
  2. suspension suggestions
    By antinora in forum Mk2 Golf & Jetta
    Last Post: 12-09-2006, 04:57 PM
  3. Suspension and brake suggestions
    By hiho in forum Mk1 Golf
    Last Post: 05-05-2006, 11:16 PM
  4. Starting Trouble... 2.0lt 1995 Mk3
    By golf-kart in forum Mk3 Golf & Vento
    Last Post: 25-04-2006, 06:18 PM
