Results 1 to 10 of 11
Thread: VR6 Intake & brakes
    Jul 2009
    nsw
    VR6 Intake & brakes
    Hi all,
    I just recently bought a stock VR6 wanting to upgrade the brake disc/pads and an intake, what would be best recommended??
    cheers =)
    Jan 2007
    I'd recommend speaking to DBA in Silverwater for some slotted brakes with uprated pads. You could also upgrade the brakes with a set of 312mm fronts from either a Bora 4motion, and Audi S3 or an Audi TT. But this in itself poses a problem as not many wheels will clear the calipers which are smaller than a 17.
    As for an intake mod, you can either cut a hole in the bottom of the air intake for more flow, or go all the way and go for a pod filter a K&N from an RB26 skyline does nicely, and make a metal/fiberglass or some other kind of heat shield to stop the hot air from entering.
    Now more importantly, where are the pics of your car !
    Feb 2007
    Perth, WA
    The stock brakes are actually quite good, you can smash the pedal and the ABS wont kick in until the very last second.
    But if you wanna upgrade em (like I do), you can get slotted rotors from DBA fairly cheaply + EBC green stuff pads that would work nicely.
    Intakes, swiss cheese mod + panel filter. Or pod filter or a BMC CDA or DIA. Depends on budget really.
    Quote Originally Posted by MattyT View Post
    No that just means you've got very good tyres, doesn't really say much about the brakes. What exact model VR6 have you got?
    GSL RallySport 1300 884 836
    Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
    QFM Performance Pads
    Feb 2007
    Perth, WA
    A 1995 Vr6 colour concept.
    My tires are ****, they're nexen 3000's. I had the same thing with the ABS when I used have pirelli p-zero's on it though.
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by gslrallysport View Post
    Sorry to have to argue the toss here, but if we're talking about the ABS system (which we shouldn't be because the OP didn't ask about it), then it's sole job is to stop the wheels skidding. If a crappy tyre is installed and is prone to skidding easier, ABS will kick in sooner, so as to ease off the brakes allowing the poor performance of the tyre to stop you later. If the tyre is (for argument's sake) the best you can get, ABS will cut in later than if using a bad tyre, simply because the grip is going to be kept under a harsher breaking condition.
    Back to the OP...I'm still waiting to find a BMC for my intake, I'm really not liking the look of my open pod filter might succumb to the styling's of Autobarn's DRiFT cold air intake.
    Quote Originally Posted by Mrk_Mickey View Post
    Um... right... that's exactly what I said...
    Sorry, I said it the other way round, ABS will cut in later if you've got better tyres...
    Generally if you're trying to argue a point and call someone a toss you wouldn't back up your final statement with exactly the same thing as they said...
    Dec 2007
    Ermington, Sydney
    I'm not going to argue with you buddy. You didn't make it clear because the post was very, very vague in the sense of technical (or elaborative) information. If anything, I said what you should have.
    P.S I wasn't calling you a toss, I was using the expression ''argue the toss''. I don't even know you!
    oh woops sorry... i definitely miss-read the toss bit... I think we're on the same page, I think just my fingers typed before my brain quite figuired out how to word it...
    Apr 2008
    I've got a set of 312mm Calipers & carriers for sale (from the Mk4 V6 4Motion Bora). They can be adapted to the VR6 (and will fit under 16" wheels) if you're interested...
    Nothing to see here...
