Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: VR6 Instrument Clusters
    Dec 2006
    Kilsyth, VIC
    After a few issues with the cluster I have now pulled both the old and new clusters apart.
    The old one's Speedo and Tacho had died. Interestingly enough, when pulled apart, the old one would not return to 0 by itself, the new one would. Is it just a different type or is that what they do when they die?
    Originally I was going to replace the temp guage and fuel guage between the two, but it turns out the old ones parts are all joined together where the new one is all separate modules. Also my old one didn't have lights for ABS at all in the cluster, they had bulb slots, but the front side was a blank. Seems maybe someone has replace the cluster with an older style one? Did VR6's ever come without ABS?
    Here are some pics, notice the new one is all little chips where the old one is capacitors!
    OLD:
    NEW:
    And the fronts:
    Notice all the bits are joined on the old one:
    New
    You will also notice the new one I got is from an auto so has an extra set of lights, luckily the housings were able to be swapped over so I could hide them.
    I'm not an expert in pulling these things apart, not really all that hard a task, but it's always fun to tinker anyway.
    Dec 2006
    Kilsyth, VIC
    Some may have noticed in the above picture, but for fun when I put the old one back together I took this photo:
    NICe one hawk..
    BTW do you have a pic of one of those bulb ? and are they all the same bulb ?
    I need to replace 2 of mine I think.
    I will also consider spraying my needle red when changing the bulb, are they easily detachable ?
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Soundofav6 View Post
    NICe one hawk..
    Yes they are all the same bulb for everything EXCEPT the lights that illuminate the down onto the speedo and tacho. They are all the same bulb holder but the orange ones are 1.2W (or something like that, they are in the garage now) the ones that shine down are grey and are 2W.
    In my case I am using the orange 1.2W ones since I don't have any 2W ones. They are bright enough so I wouldn't bother pulling it all apart to replace them with the 2W ones instead.
    As for the needles, no idea, I didn't try to remove them.
    hey hawk could you check which bulb"s" I need to replace.
    If you have a chance could you take a photo of the bulb so I can show the guys which type I would need.
    Camden, Sydney
    The old cluster has mph on the inside which are the earliest ones sold in Australia. The others are later ones.
    I have 2 more sets of VR6 clocks if you want to try swopping over gauges.
    Looks like you had fun though
    Dec 2006
    Kilsyth, VIC
    There you go:
    You want the grey osram 12V 2W bulb, although either will do fine. If your going to change one for the smaller power 1.2W, do both so one it's brighter than the other. On the upside, you can see the speedo
    Dec 2006
    Kilsyth, VIC
    It seems to work right, the older ones seem to move quicker (both up and down) at least for fuel and temp, but otherwise the new ones seem to be the same readings as the old ones.
    Quote Originally Posted by The_Hawk View Post
    Thanks man .. appreciate your help and tip.
    Jul 2007
    Constitution Hill
    you buy those osram at the dealers or some shop?
    mine keeps on dying on me. replaced it so many times now.
