Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: VR6 Head Work
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by pattso187 View Post
    Hi Guys,
    I've gotta rip my head off my 95 vr6 cause the gaskets blown. Just wondering if anyone can recommend somewhere good in Sydney or Canberra to have it ported and lightly machined while its off. I plan on going 42mm intake and 36mm exhaust valves and just cleaning up the bowl and putting in heavy duty valve springs than later on throwing in a set of 268's with a chip. Anyone think these valves will be too big? Haven't got oo much experience playing with VR's.
    Thanks,
    Patrick.
    M8 i reckon goodman race engines....He has just got all the lateset programing from the states.
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by VW Convert View Post
    That's a fairly audacious question from someone with a total of 5 posts on this forum to a respected member who has countless years of experience repairing and rebuilding VWs.
    You have entered this forum and asked questions about a specific topic and in doing so indicated you have limited knowledge of the topic. You have been offered advice from an expert in this field, perhaps you should reconsider that question.
    George
    If you read loons post it suggests you have to remove the gearbox to do the head which you dont . Ive removed a head before without pulling the box out . If you like do a search on HPA turbo conversion and you'll see pictures of how they pull the head off and fit a headspacer without removing the gearbox .
    This thread has so little useful information . Take the head here or take it there . Very few people have any real experience with these engines in this country . Porting the head and getting the right flow figures is crucial with the different runner lengths . Porting is useless without a decent cam (268 or larger) . You also cant just machine the head , there is no combustion chamber in the head on a 12V :
    if you want to machine the head you'll need to pull the valves out and probably redo the inserts . To raise compression ratio you can either run a mk4 headgasket or change the pistons .
    The only advice I can give you is take it to someone thats done one with proven gains . You'll need a chip as well as sorting out your fueling issues .
    Bug_racer supports the rebellion of the euro revolution
    Aug 2007
    Ive never removed the trans to do a head, you only would if you were going to do the chains and guides, and even then the time you spend messing around with the box i would have the whole lot swung out the front, unbolt the front off the car and pull it all forward, makes for a better job instead of leaning over an engine bay.
    Jmac
    Alba European
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by Bug_racer View Post
    Good info Sebby
    Jul 2009
    Hi Guys,
    Thanks for the info Seb. I didn't want to machine the head to gain compression. just simply to clean it up if need be. Also i will be sourcing a mk4 gasket from the states. As for George, I've been a mechanic for audi for 7 years now so i guess i have a little experience in he field. I wasn't having a stab at golf loon, simply asking the question because as a mechanic it sounds insane to me to pull the gearbox out unless you need to replace the chains and guides. Should he have stated that the chains should be replaced due to the extra valve train stress than i would understand but as far as pulling the gearbox out just for fun it doesn't particuarly make sense. I'll try contact goodman race engines tomorrow. As Seb stated it would be best to find someone with experience and proof of gains which i was hoping to find not an argument about how to pull the head off.
    Thanks for the info and contacts Seb & JVLR32.
    I'll keep you posted.
    Patrick.
    Feb 2007
    Perth, WA
    Have a chat to KI11Z, he's currently building an monster VR6 n/a engine and may know something about machining & valves, etc or put you on to somebody who can give you the info you seek.
