Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: VR6 Hard start
    Apr 2008
    VR6 Hard start
    I have problem with starting my VR6. Need to turn key few times before start engine in the morning plus need to push acceleration pedal a little bit. During day time start after 2-3 times turning key. Look similar when you start engine with spare key without immobilizer - just start and cut-off few times before start normally.
    All rest is 100% normal: power, driving, acceleration, fuel consumption....jus bad is start!
    Can be: fuel pump, fuel filter, maf sensor, fuel pressure regulator, ignition coil, fuel line, vacuum line, coilpack, crank sensor, too many to listed...........
    Any help or sugestions please.
    THANKS
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Dec 2007
    Ermington, Sydney
    If what you're describing is actually choking of the engine, my guess would have been fuel. People always told me change my fuel filter if I haven't done in a while which should help.
    Boris, I suppose if you check everything for abnormalities you should find something if not then it will be something common that one of the mechanics on here will know about.
    Ignition switch maybe? When mine was on the way out it would take 2 or 3 goes to get the car started. Was a 15min and $25 fix once I worked out what it was!!
    Apr 2008
    Quote Originally Posted by Mrk_Mickey View Post
    Thanks, I will change today because I have spare one.
    Apr 2008
    Quote Originally Posted by Lorenz View Post
    That is a good point and cheap. I will order one from USA, becasue is not expensive and change upon delivery. Thanks Lorenz
    Sep 2006
    Australia?
    Sounds like a fuel pump same symptoms in the mk1!
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by DubSteve View Post
    Didn't you change the fuel pump a few months ago bro? lol
    Sep 2006
    Australia?
    Yes only like 1 1/2 months ago week after easter.
    But I had the same symptoms on start up it would try and then nothing.
    Just reading it again it could also be the ignition immobilser.
    Apr 2008
    I find on e-bay few type of fuel pumps and all is for golf 1.8 2.0 and 2.8. I think for VR6 2.8 should be 4bar and for other 1.5-2.bar.Is it correct?
    Dec 2007
    Girraween
    the others are 3 bar
