Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: VR6 Exhaust
  1. #21
    Feb 2008
    Auckland NZ
    Quote Originally Posted by Mk3 AAA View Post
    OEM = Original equipment manufacturer, not machine. Wouldn't normally correct that, but this is a VW forum, spirit of the Germans...
    Thanks for that, work with computers all day. So ended up referring to machine instead.
    Quote Originally Posted by Ben J View Post
    Removing the suitcase is basically all for noise. Might flow a little better but the power gain is probably negligible, it does remove like 15kg of weight though. Really have to go for a full aftermarket exhaust for power gains, a good mandrel bent 2.5inch system will see some decent gains. There isnt much to be gained from putting on extractors, as far as I know thete is only one set you can buy that actually makes power, theyre expensive with tuned length pipes and such, the cheap hottuning ones just make some more noise, mighy actually lose a little power even. Porting the stock exhaust manifolds and having the downpipe backwelded and porting that too gets more gains than most extractors, I did this too and it was definitely worth while.
    These vr6 motors make one of the nicest noises of any engine in the world in my opinion, especially when they have some intake and exhaust mods, so I believe its well worth doing, even if it is just for sound. Making the engine breath easier can't hurt anything if you do it right, but wont make massive power differences until you've fixed the more restrictive parts (such as the head, which is the biggest problem on these motors)
    Sent from my GT-I9305T using Tapatalk 2
    I'm with Ben on this one. the VR6 is sound like no other.
    Additionally, the extractors only start making any gains, after you have upgraded camshafts and Shrick or VSR intake installed as well.
    Audi S4 (2001) - Imola Yellow
    Secret Project
  2. #22
    May 2012
    Melbourne, VIC
    Well didnt this turn into an informative thread about mk3 exhausts!
    alright, so after the roady I'm going to chop off the suitcase and muffler! haha just for abit of fun.
  3. #23
    Aug 2008
    Rowville, VIC
    Quote Originally Posted by mitch750 View Post
    make sure you flange it.
    just in case
  4. #24
    May 2012
    Melbourne, VIC
    Why The Face, is a flange?
  5. #25
    Jun 2011
    VR6 Exhaust
    I think he means so you can easily bolt the old system back on.
    When I bought my vr, it just had a different resonator/small muffler instead of the suitcase. And it sounded pretty good up high and quite down low, no drone etc was perfectly fine.
    I would strongly suggest not removing the muffler as it is effing loud
