that looks like a pretty strong run for a stock vr6.
is that black line the torque curve? looks stupidly flat.
Has anyone on the forum had there VR6 in the forum?
Here is the print out of mine:
Car had done around 180,000kms at the time, the only mod is a K&N replacement filter.
Um something smells fishy about this??????
AFR is all over the joint.... what year is yours?
Considering the stock flywheel torque is 235 Nm, your reading of 430Nm seems a bit odd. 109kW would be about right I would think, maybe a tad high.... Dont know about the AFR, that is all over the shop!
gearboxes will do that. only real measure of torque is an engine dyno IMHO
Every dyno run I have seen has been carried out in 4th, was this one done in 3rd like it states in the bottom of the printout?
