Sorry to hear about this.
First port of call should be a VAG-COM or V-Checker scan.
This should reveal any errors the ECU has logged and give some clues about what is going wrong.
What you're describing could happen with a failing lambda (oxygen) sensor, but then similar symptoms could come up the sensor has a bad ground or if you have a bad vacuum leak.
Check this thread - maybe a local forum member can help you with a scan:
http://www.vwwatercooled.org.au/newf...ad.php?t=27504
