Results 1 to 10 of 17
Thread: VR6 "drops" suddenly when clutch is pressed under load
    Jun 2007
    Perth
    Hi, I noticed something weird with the VR yesterday after pulling out of BP. I shifted hard into second and hada strange "dropping" of the front of the car when I pushed the clutch in. Today the car seems to be running a little weird too, in addition to this dropping on the front of the car when I depress the clutch.
    It wont do it if I slowly push the clutch in on low revs. Any ideas people?
    Sep 2006
    Australia?
    Sounds like a engine mount is it like a knocking sound?
    Apr 2006
    had that happen to me before.. while i was burning rubber..!!
    check your front engine bracket mount.. don’t drive it till you check it out! i think you might be in for a surprise! They tend to break… happened to me and few other VR’s
    Jun 2007
    Perth
    Quote Originally Posted by DubSteve View Post
    Not so much a knocking sound, but you feel the front of the car drop suddenly.
    Jun 2007
    Perth
    Quote Originally Posted by DUBING View Post
    Yeah this first happened after a flat shift
    Point Cook, Vic
    check to make sure that one of the sub frame mounts hasnt come unwelded from the front of the car. Has happened to a few people now.
    Jun 2007
    Perth
    Quote Originally Posted by Tim View Post
    eek... will do.
    Just checked then, can't see to much wihout jacking it up.
    I did notice however that there is a bunch of oil coming from the filter cover thingo...
    I think I may need to book it in to see Joe ASAP.
    Apr 2006
    Quote Originally Posted by runamuk View Post
    eek... will do.
    take off the front Vent on the drivers side.. look through it.. might help
    and looking at the engine from the top, does it look slightly tilted?
    Sep 2006
    Jun 2007
    Perth
    Quote Originally Posted by vwthunder View Post
    I'm hoping it is going to be something relatively simple like that...
    Theres also a strange intermittent hissing when you give it a little, in addition to the oil around the filter housing... Related methinks.
