Results 1 to 8 of 8
Thread: VR6 drinking oil like its owner drinks scotch
    Jan 2009
    Drummoyne, Sydney, NSW
    Gday...stright to the point i have a Golf VR6....chewing up some oil...doesnt appear to be a leak so gotta be rings or the valve seals. Havent had time to get a wet/dry comp test done yet so not too sure. What i want to jknow is how much can i expect a mechanic to charge me to redo the valve seals in australia? anyone been charged for this service before??
    cheers....
    Dec 2007
    Ermington, Sydney
    If you want to get a proper quote, PM people like Bug_Racer, Golf Loon, or even Jmac for a price guide. You should be able to get a fair, accurate priceguide for the job .
    Feb 2007
    Perth, WA
    Which scotch??
    Jan 2007
    Quote Originally Posted by MattyT View Post
    Which scotch??
    Hopefully its Ballyntynes or something equally cheap ...
    Could be a headgasket leak, do you see any leaking oil around the engine bay, at the back of the block?
    Jan 2009
    Melb, VIC
    is it blowing blue smoke?
    is there any oil residue in your cooling system?
    Jan 2009
    only had the car for a short time, got it off the folks, dad said careful oil gets low. i pumped 2 litres into it the other day, havent driven much but holding its level so far. i did rev it hard the other day and the oil light flashed, restarted the car and it went away. have wound it out since and no hassles.
    cant see smoke...but then its hard to from the drivers seat
    the head gasket has already been done, not sure exactly but shouldnt have more than 50,000kms with new gasket...
    i have noticed quite a lot of oil out the back of the motor upon inspection...would this be the head gasket or could be a number of things?
    and on the issue of scotch.....im not fussy.....whatever you want to send me!
    Jan 2009
    PS seems ok on power...would gasket/rings/valve seal leaks cause noticable power loss?
    Jan 2009
    ADL
    How many Km has it done?
    A second hand engine would be cheaper if you can get yr hands on one...bucks for a rebuild would be better spent on an R or something
    96 VR6, Black
