Results 1 to 5 of 5
Thread: VR6 Cutting Out.
    Jul 2010
    Pialligo ACT
    VR6 Cutting Out.
    Hi all ,
    Im having some troubles with my Auto VR6 . It tends to cut out when im pulling up at lights or slowing down to take a corner and is starting to idle a bit rough. Any ideas would be great .
    Thanks
    Sep 2010
    Christchurch NZ
    Hm maybe the coilpack is died/dying?
    oO= VR6 =Oo
    Feb 2008
    mOOROOLBARK
    check your vacuum lines mate
    you may have a leak
    you will hear a hissing sound
    Jul 2010
    Pialligo ACT
    Thanks , I just got it idling and there was i hissing noise happening every now and again then the revs would come up . It sounded like it was coming from the back of the motor just behind the rocker cover where there were some black hoses . would that be the vacume lines ?
    Jan 2006
    Lowood Qld
    may not be thin vacc lines but some rubber pipes deteriorated u can temp fix it with tape or silicone or various rubber pipe replacements (i used some from a graden plastic sprinkler syst.)
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
