Hm maybe the coilpack is died/dying?
Hi all ,
Im having some troubles with my Auto VR6 . It tends to cut out when im pulling up at lights or slowing down to take a corner and is starting to idle a bit rough. Any ideas would be great .
Thanks
oO= VR6 =Oo
check your vacuum lines mate
you may have a leak
you will hear a hissing sound
Wide Steelies For Sale
http://www.vwwatercooled.org.au/foru...ies-76972.html
Thanks , I just got it idling and there was i hissing noise happening every now and again then the revs would come up . It sounded like it was coming from the back of the motor just behind the rocker cover where there were some black hoses . would that be the vacume lines ?
may not be thin vacc lines but some rubber pipes deteriorated u can temp fix it with tape or silicone or various rubber pipe replacements (i used some from a graden plastic sprinkler syst.)
german - english translations esp vw documents!!
Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
