Results 1 to 10 of 19
Thread: VR6 "cutting out" at 3500rpm on full throttle
    Jun 2007
    Perth
    Anyone ever had a similar issue? Someone mentioned there is some "anti-flog" thing that wont let you hurt you car when cold... but this is something else.
    Even when the car has been running for over 30 mins, the issue still occurs sometimes.
    If I slowly creep up the RPM, it's ok, but if I hit full throttle, it will cut out just when the car usually gets its power. If I hold my foot on the accelerator, the engine wont be running at all, and when I release my foot, the engine kicks back in.
    Any ideas?
    Point Cook, Vic
    what have you tried so far?
    Sounds like leads or coilpack to me. Have you eliminated them?
    Point Cook, Vic
    have u had it scanned for codes yet?
    Jun 2007
    Perth
    Not as yet... gotta do a 400km drive tomorrow too
    And codes... hrm yeah, not too keen on taking to VW.
    It actually seems to be doing it a lot more often since I put MattyT's stock airbox in her.
    Quote Originally Posted by Tim View Post
    Feb 2007
    Perth, WA
    Awww just because you dont have your luvley K&N filter on it anymore
    I have no idea what might be causing it. Codes might say
    Point Cook, Vic
    when you change the air filter back steal MattyTs ignition leads.
    If that doesnt work. Steal his coil. See if it helps
    also
    Buy one of those cheap scanners off ebay for $15. They ship direct from asia and only work with the old version of the vag-com software but it will be enough for you to scan the car if you have access to a laptop
    Did you touch any of the clamps after the MAF when you installed the airbox? You may have non-metered air sneaking through causing it to go into limp mode...
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Jun 2007
    Perth
    Possibly... I'll check that out tonight.
    Quote Originally Posted by 99gti View Post
    Feb 2007
    Perth, WA
    We fiddled around with alot of stuff trying to wedge the airbox in. His freakin engine block was a few cm over to the right then mine, making it a huge hassle to get the airbox in. I'm pretty sure we even removed the MAF entirely at one point.
    ps. dont steal mah leads n coils, dey is mine!!
    Jun 2007
    Perth
    Hey! Look over there! YOINK!
    Quote Originally Posted by MattyT View Post
