Results 1 to 10 of 10
Thread: VR6 clutch kit
    Sep 2010
    Southern Highlands NSW
    Quote Originally Posted by peedman View Post
    not sure about clutch forks but u got a new throwout bearing right?
    whilst your there i reckon u should change the rear crank seal just in case as you can get to it at the same time, if it happens to leak later on then its gearbox off again so i think its good piece of mind.
    you should also consider the timing chain as you've already going to take the gearbox off so your more than halfway there.
    are u diying or getting a mechanic to do it?
    Yeah i got a throwout bearing and the rear crank seal came with the clutch install kit with various others bolts & pieces. As far as doing the chains i would love 2 but money is a bit tight at the moment as im going 2 have 2 pay a mechanic 2 do the work because
    i dont have any of the tools & equipment needed 2 pull this off . I need the car done before the trip 2 melb for DOVW and its also my daily.
    Point Cook, Vic
    definately get the chains done whilst the gearbox is out. Will be cheaper to get them done now than it will to replace a broken engine.
    FOLLOW US ON FACEBOOK
    Oct 2006
    Quote Originally Posted by mrVR6exy View Post
    Mate if u consider doing diy me and rayray can prob give u a hand since ur close to him and me. I reckon a weekend and we could have it done!
    Eastern suburbs of Melb
    definitely chains!!!!!!!!!
    DIY...get some help...much more satisfation!!!
    Nov 2007
    Williamstown, Vic
    Definitely get a new clutch fork too. I had my clutch replaced by VW at 185,000 kms. I asked them to replace anything that was usual at the time of a clutch change. They didn't replace the fork. 30,000kms later the fork broke and I was up for a similar expense of having it all fixed.
    Sep 2010
    Thanks heaps for the offer Pedro, that would be great if i could grab a hand but i have never pulled off a timing chain job and clutch install before ! and my skills with a spanner are still in the infancy stage haha ! Im keen 2 have a crack though... how difficult is a timing chain change on a VR ?
    Point Cook, Vic
    timing chain isnt a hard job once the gearbox is out but the consequences of getting it wrong are pretty severe!
    Sutherland Shire, Sydney
    mrVR6exy - what was the rough amount that the mechanics were asking for a clutch change usual other items associated with a clutch change?
    mine is coming up to 150K need to start saving a bit over the next few months
