Results 21 to 30 of 33
Thread: VR6 brake upgrade. anyone done one?
  1. #21
    Apr 2006
    my vr6 had its brakes upgraded, the first owner done it, but i had no idea what they were.. one of my mates said they look like Rx7 brakes..
  2. #22
    Dec 2006
    Kilsyth, VIC
    When it comes to the rear brakes, is there anyway to move some of the braking force to the back? Or does this become a long complcated job that involves replacing the entire braking system?
  3. #23
    Sep 2006
    Australia?
    This is a interesting thread and I have done the 280mm brake conversion to 288mm!
    For the 312mm upgrade you need a set of 17s before you can even think of attempting the upgrade cause 16s won't fit, there huge and have some good stopping power but you need alot more than what you guys are saying!
    Quote Originally Posted by MattyT View Post
    Well I do have 280mms. Maybe I should order 288mm slotteds and the other bits needed? Hmmmmm
    Matty, I recommend the upgrade I already had slotted rotors front and back, so I went with another slotted set 288mm with Redstuff brake pads slightly more aggressive than the greenstuff pads which I have on the back.
    What you will need are new brake lines, calipers and rotors and might as well change the brake fluid when you get the chance.
  4. #24
    Aug 2006
    Melbourne VIC
  5. #25
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by DUBING View Post
    You dont have a photo of your brakes do you? we may be able to ID them.
  6. #26
    Apr 2006
    Quote Originally Posted by ScienceVR6 View Post
    there you go.. tha caliper was 1mm away from the rim.
  7. #27
    Feb 2007
    Perth, WA
    Quote Originally Posted by Mk3vr6 View Post
    Yeah I heard that. Was thinking new braided lines, calipers and the rotors + motul RBF600. I wonder how much all that would set me back?
  8. #28
    Point Cook, Vic
    they look like 288mm brakes?
  9. #29
    Aug 2006
    Skye, Victoria
    they appear to be the factory 288mm brakes.
    I have EBC Black stuff on the back and what i was told is green stuff on the front.
    Stops magically, however i am going to swap the fronts over to a new set of greens shortly and add extra anti squeal paste... noisy buggers. will report back then.
    fyi mine are 280mm
  10. #30
    Sep 2006
    Australia?
    Well Matty for 288mm slotted rotors I paid $600 plus the pads and new lines. New brake lines are a must you can't use the 280mm ones!
