Results 1 to 6 of 6
Thread: VR6 brake caliper guide pins - hex Size???
    Nov 2006
    bondi
    Getting frustrated!
    Went to change the pads in the VR6.
    Its a late '96 model so has the Teves ATA calipers.
    Anyone know the size hex driver (allen key) needed to loosen the guide pins?
    Its bigger than a 6mm and smaller than an 8mm (as I found out after putting the wheel back on, heading out to the hardware store and pulling the wheel off again).
    Before I try to find a 7mm key, just wondering if it could be an imperial size??
    Oct 2006
    sydney
    7mm allen key bit would be the go on a 3/8 rachet
    May 2006
    byron bay area
    I would tip 7mm, I had the same situation in a mk1 srtut tower
    most hardware shops did not carry 7mm, i got lucky at a engineers supply shop
    good luck
    Sep 2006
    West Sydney
    Hard to find a small set with a 7mm allen key let alone by itself. I had to get a complete set to grab a 7mm of my own
    get an 8 and file it down to fit.
    Or buy a proper 7mm fro snap on or someone
    Nov 2006
    bondi
    yep its a 7mm metric
    pads changed
    all is well.
Similar Threads
  1. Mk1 Commodore Caliper, 278mm Magna rotor conversion
    By golfnutracing in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 06-06-2011, 04:23 PM
  2. Audi S3 brake upgared (Caliper painting)
    By PoloGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 26-11-2006, 01:42 PM
