7mm allen key bit would be the go on a 3/8 rachet
Getting frustrated!
Went to change the pads in the VR6.
Its a late '96 model so has the Teves ATA calipers.
Anyone know the size hex driver (allen key) needed to loosen the guide pins?
Its bigger than a 6mm and smaller than an 8mm (as I found out after putting the wheel back on, heading out to the hardware store and pulling the wheel off again).
Before I try to find a 7mm key, just wondering if it could be an imperial size??
I would tip 7mm, I had the same situation in a mk1 srtut tower
most hardware shops did not carry 7mm, i got lucky at a engineers supply shop
good luck
Hard to find a small set with a 7mm allen key let alone by itself. I had to get a complete set to grab a 7mm of my own![]()
get an 8 and file it down to fit.
Or buy a proper 7mm fro snap on or someone
yep its a 7mm metric
pads changed
all is well.
