Results 1 to 9 of 9
Thread: Vr6 auto to manual help
    Feb 2013
    Vic
    Hay guys looking to see if anyone can point me in the right direction or give out any pointers. Currently have completed an auto to manual converstion in a mk3 vr6 I'm currently having issues starting to car. Could anyone give any hints out to what I have to do?
    Does anything happen when you try to start it?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2012
    Central Coast, NSW
    changed the ecu to a manual one? Imagine trying to start the car not in Park mode on an auto. Won't work. If ecu isn't receiving that then it wouldn't start I'd suspect. Obviously also the manual starter is different to the auto one. The more information you can give us on what you've done and what it's doing the more likely someone can help you
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by anthony--t View Post
    It does work, I do it all the time after having parked in neutral.
    Past - '95 VW Golf MK3 VR6
    Mar 2012
    Central Coast, NSW
    Ok. Park or neutral. Bet it doesn't work in Drive or Reverse. I was implying about the transmission selector letting the ecu know it can start the car.
    Dec 2008
    Sydney/Canberra
    There's an inhibitor relay you need to bypass.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2013
    Vic
    Hay when you go to crack does nothing no clicking sound from the starter motor. Im running the manual starter motor. I've got a donor car which I have taken all the parts off. I've plugged the ecu off the manual and same thing happens also comes up with a error code on Ross tech that engine start is blocked by the imboliser. I've also disconted the auto ecu dash doesn't display it being in park.
    Feb 2013
    Vic
    Where is the inhibitor relay located and which wires get by passed
    Mar 2008
    Melbourne, VIC
    Read this: VWVortex.com - 020 Manual Swap FAQ/DIY
    If you still have the auto wiring in there, you may have to jumper the 6-pin plug that used to sit below the battery on the transmission to make the car think it is permanently in neutral.
    Past: '77 VW Golf GLS Mk1 3-door, 2 x '95 VW Golf CL Mk3 3-door, 2015 Mk7 90 TSI Manual
    Present: 2018 VW Golf GTI Original Manual Mk7.5, 2006 VW Caddy Life Camper
