ok, well thanks to my cousin and some moral support from Neroo (whom i bought the brakes from), they're now fitted to my VR.
Here is what you need to know:
I bought the complete kit from Neroo from his part out V6 Bora. The kit had the calipers (with complete brake lines), carriers, pads and 312mm rotors.
I bought 4x 40mm high tensile (10.9), fine pitch (1.5) hex head bolts from Dandy Bolts for $7
I sourced 3mm washers from the UK for $10 shipped for a pack of 10. You need 2 for each bolt
The brakes bolt straight in, but...
The brake hoses will connect to your existing lines, but the clips that mount the lines to the body do not fit. I used zip ties.
You will also need to lose your brake guards.
The brake pad sensor connectors are also different and will need to be soldered and resisted (im putting up with the CEL for now).
Weight difference is substantial. The old setup is quite light compared to the new hardware, but the stopping performance is simply AMAZING!
My previous setup was 280mm so i needed to change the caliper also. Those sporting 288mm calipers can just change the rotors according to many sources.
Before and after pics:
Hope that helps
- You may not post replies
- You may not edit your posts
Forum Rules
