wheel bearing or warped rotor.
Hey fella's well i have decided to keep the car after all!
Now its sprung a little problem.
When in driving, im getting a vibration coming throught the steering but it stops when i turn the steering wheel left.
For example, when driving on freeway load noisey vibration but if there is a sweeping bend to the left the sound and vibration stops!
Its anoying the crap out of me! Its not wheels and tyres cos had them checked out on sunday.
PLEASE HELP!
peedman had a similar problem - it came out to be his tie-rod ends.
I have same problem. just a very light vibration when pulling right but gone after wheel in neutral position. Now the vibration is inhibited, kinda forgot about too.
It's not a "problem" is it ?
can also be simply a wheel alignment. take it to a wheel place to get em checked. they will do a check and straighten them for about $40. If it is just something to do with the alignment, it will be fine. If not, they will probably be able to tell you what needs to be done.
Check that the wheels are tighten I had this problem with mine when I braked it stopped, turned out my wheel was lose![]()
