Results 11 to 20 of 32
Thread: Vibrating Noise
    Oct 2006
    If its a loose wheel u can really hear it and it sounds that something is definately wrong.
    Is it at high speeds only or pretty much all the time?
    Sep 2006
    Australia?
    Quote Originally Posted by peedman View Post
    No pretty much all the time, can't be a lose wheel me and my dad checked out the wheel and retightened the adapter and everything.
    Aug 2006
    didnt you say you put the tyres on your rims at home ur self? maybe it needs balance n allignment.
    gpk_gti Guest
    my money is on the disc being warped.its noticable now since he put those big adaptors on.
    Mar 2007
    Balancing weights fallen off?
    Quote Originally Posted by Mk3vr6 View Post
    Hey all dubbers,
    I have a problem with my front left wheel. When the car is in motion it vibrates I have no idea. Me and my dad checked out the wheel on Saturday, thought it might be the adapter but it wasn't. When the car is rolling forward or even going at about 80khm, it still vibrates abit. When I put my foot on the brake it stops making the sound
    I have no idea what it could be, can anyone help me.
    I've seen it happen. If the wheel has lost the alignment weights, it could have an induced 'shimmy'.
    D.
    gpk_gti Guest
    rims are 1 week old,could have fallen off.swap the rims around and see what happens
    May 2006
    Maryborough Vic
    Talking
    the stick on weights used to balance mags
    often fall off, more so on new rims cause some
    fitters don't clean where the weight is put, like
    you would an older rim
    but bad balance is generaly only at different
    speed ranges eg : 60-80 80-100
    not constant !
    if it is low speeds could be tyre fault
    diffinately move wheel to see if prob follows
    (i'll go and club myself a wife now)
    Aug 2006
    Skye, Victoria
    wheel bearing maybe? because of the spacer there is more of a lever action acting on it?
    Mar 2007
    Are they new tyres?
    Hey all dubbers,
    When I took delivery of my Polo the Contis on it made a funny vibrating noise on very smooth tarmac. Salesman said they just needed to wear the nubbly bits off and they'd settle down. They did ... eventually ( @ about 5000k).
    Otherwise ... don't know what to tell you. Previous car (a Toyota) had a shimmy in the steering for the 8 years I had it ... no one could do anything with it - wheel alignments, balancing ... nothing made any difference. At 100kph ... there it was ... right 'til I traded it on the dub ... (and oohh the relief )
    Dave
    Sep 2006
    Australia?
    Quote Originally Posted by DaveMack View Post
    Dave
    The Fords actually have that problem, they need to add a shim to the steering. Checked the wheel last night and the adapter bolts 2-3 were lose WTF, anyway my dad used locktight, and today we are taking the car to get the wheel rebalanced and get the front realigned. It needs a alignment.
