If you are low enough maybe
Hey guys,
Trying to work out if I can run 16x9 +15 borbet type A's all around on the vento, or will i need to go staggered?
Don't mind rolling the guards and pulling them out a little, but don't want to have to do huge amounts of guard work.
Cheers,
Luke
It's been done before. You will need to pull and pump your guards as much as possible. Lots of stretch and camber.
You'd be better off going for either a skinner set or higher offsets if you don't want to work your guards.
If you literally type in "16x9 +15 on mk3" into google I'm sure there's plenty of threads about this on vortex. (I've read them) that'll give you an idea of how it looks.
okay cheers guys
