Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 117
Thread: Vento VR6
  1. #51
    Mar 2014
    Bundoora, Victoria
    In the Golfs the central locking pump. sits on the rear right tail light bulb cover.
    Where did you get the washer jets from?
    One of mine is now a three jet...sprays cars to my right, lol.
  2. #52
    Apr 2008
    NSW
    I took all of mine out. So i have literally everything
    May need to do a DIY one day if the central locking isnt present in the Vento
    Quote Originally Posted by stefcio007 View Post
    Ah thanks for that. Yeah, nothing in the Vento unfortunately.. Hopefully its somewhere and just playing a game of hide and seek
    I got the washer jets when I was making purchases from EuropaParts for both my MK6 and the Vento. $2.50 each. The website says the part is a Febi-Bilstein which is an aftermarket supplier but it came in a VW box and has the part number as well. But its just a washer and I would have opted for a cheaper one anyway as long as it worked. It's not worth buying from here unless you get other stuff as well as shipping would not be worth it.
    I found this :
    2 X VW POLO GOLF mk3 FRONT WINDSCREEN WASHER JETS NOZZLE WATER SPRAYER | eBay
    equates to about 15 bucks delivered?
  3. #53
    Q
    Car defs had central locking, no clue where pump is located, not the same spot as Golfs but likely the same system. From memory it did work early days. Maybe follow the vacuum lines. There was an inner guard protecter missing from front left (maybe right) that had a vacuum reservoir attached, could be related.
  4. #54
    Q
    What's the difference between Euro plate tub and Aus delivered? I was going to put a narrow recessed US/JDM etc one in.
  5. #55
    Sep 2006
    West Sydney
    Quote Originally Posted by Mk3 AAA View Post
    Same tub!
  6. #56
    Apr 2008
    NSW
    Sweet! Thanks for that! Gonna have a look tonight!
    Quote Originally Posted by rayray086 View Post
    Same tub!
    Yup same tub! Got some euro plates coming so it will fill it in nicely.
  7. #57
    Munno Para West Adelaide
    How much bigger is the piping? Couldnt use a heat gun to soften it up and slide on?
  8. #58
    Apr 2008
    NSW
    Quote Originally Posted by dubster99 View Post
    I didnt have a heat gun on me at the time. The hole for the vacuum line tubing is smaller than the nozzle on the pump. Here's the bit that was cut off.
    Heat Gun may soften the plastic vacuum tubing but gotta borrow one from a mate.
  9. #59
    Ahk so it goes from vac hose to fitting then fitting onto pump?
  10. #60
    Apr 2008
    NSW
    Yes that was what I had initially. THe fitting wouldnt fit over the new pump thats why I cut it off, only to find out the tube doesnt go over the new pump. Gonna heatgun it and see if it works that way
