Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 117
Thread: Vento VR6
  1. #41
    Apr 2008
    NSW
    Quote Originally Posted by vdubin View Post
    Cheers ,Yep that was mine, I still own the rusty bonnet Ha, It's now in Sydney on coils a couple guys have spotted it here & there.
    PS. Bring this car to vits next year with the rest of the Sydney crew
    Yeah I plan to. Will also try and get someone to drive the R down as well. Never been to VITS before so i'll be popping my virginity with me putting two cars in
  2. #42
    Apr 2010
    Albury
    Quote Originally Posted by stephen8512 View Post
    Awesome news ! Drag Bima and Ray down too
    - VITS 2016 24th April -
    Albury nsw Search vits on FB
    @vitsvw @vdubin_
  3. #43
    Apr 2008
    NSW
    Accumulating parts again :
    Victor Reinz VR6 gasket set. When doing timing chains + clutch, will also be doing full gasket replacement
    Rear euro number plate tub. Second hand from VWVortex all the way from Ireland. Will be refreshing this with a DIY and filling in the holes.
    Pioneer Headunit. Something cheap and affordable. I'm not a sound guy and just want some music playing since at the moment, all the speakers in the Vento are goneski's except for the passenger tweeter. Some speakers werent hooked up either but thought I'd do a full replacement and refresh on the sound system
    Main reason I got this was that it lights up green, as does the rest of the cars interior dash lights.
    OEM Retro tape deck
    Refresh
    Lucky 8's...
  4. #44
    Apr 2008
    NSW
    Whenever I would turn the fan on, it would blow bits of old, 20 year old foam through the vents. Decided to take the vents off, take off the dash plastics and clean what I could. Great thing about these cars is, you can take off everything pretty much with a philips head screwdriver and a dash removal tool. Just have to be careful not to break the plastic as it is a bit more brittle than something like the MK6
    As I was doing this, decided to take out the factory headunit as well.
    Here is the OEM connector which hooks up to the wiring loom inside the dash. As you can see, it's frayed, and has seen better days.
    Also, replaced the windshield washer jets. Brand new OEM VW part. The old washer on the driver side was clogged and wouldn't spray.
    New on the right. Old on the left. You can see the jets have deteriorated.
    Received the hood lift struts made specifically for the MK3. Cheap and effective mod and gets rid of the "stick" being in your way when working in the engine bay.
    The Vento never came with a keyless entry system or anything like that. It only unlocks the driver side when I unlock it with the key from the driver side. I suspect either the Vento has a failed central locking pump or it's simply non existant. Either way, I picked up this genuine central lock pump for cheap (second hand but in perfect working condition, complete with cover). All I gotta do now is locate the original pump (if it had one, which I am hoping), replace it with this one and hopefully it's happy days.
  5. #45
    Apr 2008
    NSW
    Engine bay freshness. New engine bay plastics. I'm going to keep the old ones and do a refurb on them later on, but scored some brand new plastics.
    Old :
    Comparison
    I also noticed one of the bolts were sheared off. FFS...this is gonna be a pain in the ass to remove...Any ideas on how to remove this?
    Installed. So much nicer. Cleans the bay up nicely. Also cleaned the ignition leads and removed any grease/residue from them.
    My passenger side door mouldings was starting to come apart and lift off the door. Got some OEM clips and replaced all the clips on the passenger front moulding. At the moment, I've only done just the one but will be replacing it on all the mouldings.
    Old. Pryed the existing clips off with a plier. Didn't matter if I cracked it because I was replacing the whole thing anyway
    New clips
    Ready to be installed :
  6. #46
    Jun 2011
    Do work! This is will be mint again.
    I have all the central locking stuff if required.
  7. #47
    Mar 2014
    Bundoora, Victoria
    so much happening, great thread!
  8. #48
    Jul 2015
    Roseville, NSW
    Looks mad! those clips for the door trim are a pain lol
  9. #49
    Apr 2008
    NSW
    Quote Originally Posted by stefcio007 View Post
    Thanks mate! Still a lot needs to be done before she's done...one step at a time
    Quote Originally Posted by Jon96 View Post
    Agreed! But hey, new rubber on the clips should help them stay in place for a while longer hahaha
    Thanks mate. I tried looking for the central locking pump in the Vento, I just cant seem to find it? I think on the MK3 Golf's they are located on the driver side in the boot on the sidewall? Also, what other central locking "stuff" have you got?
  10. #50
    Jun 2011
    I took all of mine out. So i have literally everything
