Yeah I plan to. Will also try and get someone to drive the R down as well. Never been to VITS before so i'll be popping my virginity with me putting two cars in :)
Printable View
Accumulating parts again :
Victor Reinz VR6 gasket set. When doing timing chains + clutch, will also be doing full gasket replacement
http://www.vwwatercooled.com.au/foru...1198011a-1.jpg
http://www.vwwatercooled.com.au/foru...IMAG0753-2.jpg
Rear euro number plate tub. Second hand from VWVortex all the way from Ireland. Will be refreshing this with a DIY and filling in the holes.
http://www.vwwatercooled.com.au/foru...IMAG0754-2.jpg
Pioneer Headunit. Something cheap and affordable. I'm not a sound guy and just want some music playing since at the moment, all the speakers in the Vento are goneski's except for the passenger tweeter. Some speakers werent hooked up either but thought I'd do a full replacement and refresh on the sound system
Main reason I got this was that it lights up green, as does the rest of the cars interior dash lights.
http://www.vwwatercooled.com.au/foru...IMAG0751-2.jpg
http://www.lifestylestore.com.au/med...1_b2_large.jpg
OEM Retro tape deck
http://www.vwwatercooled.com.au/foru...IMAG0749-2.jpg
Refresh
http://www.vwwatercooled.com.au/foru...IMAG0750-2.jpg
Lucky 8's...
http://www.vwwatercooled.com.au/foru...IMAG0742-2.jpg
Whenever I would turn the fan on, it would blow bits of old, 20 year old foam through the vents. Decided to take the vents off, take off the dash plastics and clean what I could. Great thing about these cars is, you can take off everything pretty much with a philips head screwdriver and a dash removal tool. Just have to be careful not to break the plastic as it is a bit more brittle than something like the MK6
http://www.vwwatercooled.com.au/foru...IMAG0767-2.jpg
http://www.vwwatercooled.com.au/foru...IMAG0768-2.jpg
As I was doing this, decided to take out the factory headunit as well.
http://www.vwwatercooled.com.au/foru...IMAG0756-2.jpg
Here is the OEM connector which hooks up to the wiring loom inside the dash. As you can see, it's frayed, and has seen better days.
http://www.vwwatercooled.com.au/foru...IMAG0757-2.jpg
http://www.vwwatercooled.com.au/foru...IMAG0758-2.jpg
Also, replaced the windshield washer jets. Brand new OEM VW part. The old washer on the driver side was clogged and wouldn't spray.
New on the right. Old on the left. You can see the jets have deteriorated.
http://www.vwwatercooled.com.au/foru...IMAG0745-2.jpg
Received the hood lift struts made specifically for the MK3. Cheap and effective mod and gets rid of the "stick" being in your way when working in the engine bay.
http://www.vwwatercooled.com.au/foru...IMAG0773-2.jpg
http://www.vwwatercooled.com.au/foru...155_x800-1.jpg
The Vento never came with a keyless entry system or anything like that. It only unlocks the driver side when I unlock it with the key from the driver side. I suspect either the Vento has a failed central locking pump or it's simply non existant. Either way, I picked up this genuine central lock pump for cheap (second hand but in perfect working condition, complete with cover). All I gotta do now is locate the original pump (if it had one, which I am hoping), replace it with this one and hopefully it's happy days.
http://www.vwwatercooled.com.au/foru...IMAG0778-2.jpg
http://www.vwwatercooled.com.au/foru...IMAG0779-2.jpg
http://www.vwwatercooled.com.au/foru...IMAG0780-2.jpg
Engine bay freshness. New engine bay plastics. I'm going to keep the old ones and do a refurb on them later on, but scored some brand new plastics.
Old :
http://www.vwwatercooled.com.au/foru...IMAG0781-2.jpg
Comparison
http://www.vwwatercooled.com.au/foru...IMAG0782-2.jpg
I also noticed one of the bolts were sheared off. FFS...this is gonna be a pain in the ass to remove...Any ideas on how to remove this?
http://www.vwwatercooled.com.au/foru...IMAG0783-2.jpg
Installed. So much nicer. Cleans the bay up nicely. Also cleaned the ignition leads and removed any grease/residue from them.
http://www.vwwatercooled.com.au/foru...IMAG0786-2.jpg
http://www.vwwatercooled.com.au/foru...IMAG0787-2.jpg
My passenger side door mouldings was starting to come apart and lift off the door. Got some OEM clips and replaced all the clips on the passenger front moulding. At the moment, I've only done just the one but will be replacing it on all the mouldings.
Old. Pryed the existing clips off with a plier. Didn't matter if I cracked it because I was replacing the whole thing anyway
http://www.vwwatercooled.com.au/foru...IMAG0788-2.jpg
New clips
http://www.vwwatercooled.com.au/foru...IMAG0789-2.jpg
Ready to be installed :
http://www.vwwatercooled.com.au/foru...IMAG0790-2.jpg
Do work! This is will be mint again.
I have all the central locking stuff if required.
so much happening, great thread!
Looks mad! those clips for the door trim are a pain lol
Thanks mate! Still a lot needs to be done before she's done...one step at a time
Agreed! But hey, new rubber on the clips should help them stay in place for a while longer hahaha
Thanks mate. I tried looking for the central locking pump in the Vento, I just cant seem to find it? I think on the MK3 Golf's they are located on the driver side in the boot on the sidewall? Also, what other central locking "stuff" have you got?
I took all of mine out. So i have literally everything
