G'day and welcome Ventogirl. Nice to have another female aboard! The Vento motor is basically the same as the Golf's. I'm certain that one or more of the guys can help you out......Originally Posted by ventogirl
hi guys, im looking to get performance cam for my 1996 VW Vento 2 Litre, and was wondering if anyone knows of any performance cams that i could put in AND would be a straight swap.
ive heard that the cam from the older golf gti would be a straight swap? does anyone know if this is true![]()
any other suggestions?
thanks![]()
Welcome VentoGirl, like Brackie said good to have another female member of this forum. Where abouts are you from? Any pics of your car?
A good air induction and a exhaust very nice![]()
I have heard of folk fitting the 2 litre cam into a G60 for a small increase.
I would have a look at a few American sites for guidance on cams. Maybe ecstuning.com or performancecafe.
You need to be careful with the car having a cat as long duration cams will upset the lambda probe and ECU.
GAvin
Anything over around 260 starts playing around with ECU and pollution control in ECU . You could probably run a 268 with adjustable cam gear . Giac does a Cam chip combo to get the most out of the cam .
im not looking for a cam with crazy amounts of lift, just hoping something might be out there which would be an improvement over the standard cam and requires no other mods.
as i said before, hopefully someone could shed some light on a older version golf gti cam, as i heard that these may be a straight swap
Yes you're right it will be interchangable with an older (but still hydraulic lifter) Gti camshaft. Eg. a mk2 Gti(aussie import) camshaft. To be honest I'm not sure how much of a performace gain it would be possibly a 5-10 hp or possibly less I really can't remember the cam specs.
mk2 GTi 16v
Corrado G60
Check out
http://www.autotech.com/prod_engine_...fts.htm#8vcams
and look at the sport 260 Hydro, it mentions not having to update the ecu and also fits mk3 2L.![]()
mk2 GTi 16v
Corrado G60
exactly what i was looking forOriginally Posted by ausgolfer
thanks!
I used the Auto tech 270 in a Mark 2 Gti and it was a noticeable improvement especially with the 'Euro down pipe' which you don't have to worry about with the Vento because it already has a good down pipe. I would recommend it for the Vento and if you decide to get one PM me as I have been thinking about getting another one for my wife's Vento.
