Page 5 of 14 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 134
Thread: The Vento
  1. #41
    Jun 2007
    Eastern Suburbs Melbourne
    whilst you're at it, you may as well fix the mass rear toe you'll have too (like camber shims just in a different angle)
    i like volkswagens
  2. #42
    May 2012
    That 2degrees...
    Where do i get some of these camber plates?
    And yeah im gonna fix the toe in as well.
  3. #43
    Aug 2012
    Kangaroo Valley, NSW
    May 2012
    cheers dude, reckon the eibach ones are the go.
  5. #45
    Apr 2012
    Milperra, N.S.W
    Re: The Vento
    The shims are good if you do it right, you only get one try. I used some and got my calculations wrong, had way too much toe in. That's why a resorted to one thick washer on each front lower stub axle bolt.
    '95 Golf 3dr... low. slow. loud.
  6. #46
    May 2012
    ill follow this guide, and hopefully it will work
    GolfGTIforum.co.uk - An independent forum for Volkswagen Golf GTI enthusiasts.
  7. #47
    Apr 2012
    Milperra, N.S.W
    'nother guide here: VW Volkswagen GTI-VR6 List - Old Library
    Just snip the correct tabs out of the shims and you'll be good
  8. #48
    In the mk4 the shims only work with a car at x height, too much lowering past that = excess toe in, too much above the height and too much toe out.
    I'd imagine it would be similar on a mk3 based on the rear beam design. Not sure if it rolls as much as the mk4 tho...
  9. #49
    Apr 2012
    Milperra, N.S.W
    Re: The Vento
    Yeah, well basically the chart in the instructions for the mk3 came to an end if you wanted maximum camber and minimum toe-in.
  10. #50
    Aug 2009
    ACT
    The Vento
    I'm yet to try it, but if you jack the rear beam up and simply rotate the shim so that it's set at the desired setting and cut out the bolt holes instead of following the instructions it "should" work.
