Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 134
Thread: The Vento
  1. #21
    Jun 2007
    Eastern Suburbs Melbourne
    What are your camber settings like? There are a few possiblities - most relate to the car being very low!
    oh, and try jacking the front cross memmber up first, this should give you enough height to get a jack under the sill/subframe.
    i like volkswagens
  2. #22
    May 2012
    fitted the wheels up this afternoon, the fitment is spot on. could not be happier with the way it looks...
    the problem is im rubbing a tad on my brakes, i think what ill do is just grind a touch off them and it should be sweet. i rolled the passenger rear guard and strangely enough the drivers side had already been done??
    im yet to touch the front, ill have a go at that as well tomorrow.
    oh and my front camber is as far negative as it goes
    pictures (are heaps **** because of sunlight and phone quality):
  3. #23
    Aug 2012
    Kangaroo Valley, NSW
    The Vento
    The rear needs a little camber and it'd look the tits.
  4. #24
    Jun 2012
    wollongong
    looks awesome man, nice work.
    Yer i agree more camber on the rear
    Something new
  5. #25
    Mar 2012
    Central Coast, NSW
    The Vento
    I started rolling the rear in preparation for the enkeis I was going to put on and then ran out of daylight that day and never got around to doing the others haha. That's why one was already done. Your welcome!
  6. #26
    Mar 2012
    Central Coast, NSW
    The Vento
    Looks awesome by the way, looks like the wheels fit great!
  7. #27
    Apr 2012
    Milperra, N.S.W
    Re: The Vento
    Soooo good for eBay cheapies!!!! Plastidip them a different colour every few months :p
    '95 Golf 3dr... low. slow. loud.
  8. #28
    Aug 2012
    The Vento
    Quote Originally Posted by shooitt View Post
    Do it.
  9. #29
    Mar 2011
    Bunvegas, Western Australia
    They look so awesome dude haha!
    1976 VW Golf "Swallowtail" - Rallye Red (long term resto)
    2009 Pirelli GTI - Stg3 killer
    2009 R36 Passat - Daily baller
    You take corners on three wheels, and V8's can't catch you.
  10. #30
    Jun 2007
    What I suspect to be the problem is that the end of driveshaft is rubbing on the gearbox flange. This is due to the play in the CV's (that allows the DS to move 'sideways') and the extreme lows combined with the max neg camber has the effect to push the DS in. (it's fixed at the wheel end, essentially)
    Solution: well to prove the theory correct, raise the car and or pull out the camber. If this fixes it, then it's probably as described above. Permament solution is to mill down the end of the DS (by about 5 mm, also push the CV 5mm back, and the circlip groove as well) and then run as low and cambered as it.
    How low is the car? Front of the sills/pinch welds and subframe?
    i like volkswagens
