Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 134
Thread: The Vento
  1. #31
    May 2012
    How low is the car? Front of the sills/pinch welds and subframe?
    the sills are 40mm, the lowest point on the car is 30mm.
    thanks for all the comments guys, im really stoked with how it turned out for a first fitment. theres a bit of tweaking to do but it shouldnt take long
  2. #32
    May 2012
    Quote Originally Posted by Smeeeb View Post
    The rear needs a little camber and it'd look the tits.
    whats the best way to adjust rear camber? fronts piss easy just hoping the rear is as easy
  3. #33
    Aug 2012
    Kangaroo Valley, NSW
    The Vento
    Quote Originally Posted by Surfpig View Post
    Unless you have camber adjustments on your coils you'll have to buy some piss easy to get. I've seen a couple floating around. The front camber is nice matching that would look tops.
  4. #34
    Mar 2012
    Central Coast, NSW
    Pretty sure you need camber shims. However some people ghetto it with washers.
  5. #35
    May 2012
    May 2012
    Aug 2012
    The Vento
    Go more aggressive than that do like 5 or so degrees. Drop the rear and little more get some nice poke.
  8. #38
    Apr 2012
    Milperra, N.S.W
    Re: The Vento
    Quote Originally Posted by anthony--t View Post
    I certainly wouldn't use washers >_>
    <_<
    '95 Golf 3dr... low. slow. loud.
  9. #39
    Jun 2011
    The Vento
    That 2degrees...
  10. #40
    Aug 2012
    The Vento
    That 2degrees...
    Two would look sweet then. I have nothing to compare them to in my head.
