Page 10 of 14 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 134
Thread: The Vento
  1. #91
    Aug 2009
    ACT
    take wooden blocks to the steering joint and get it up there. you're wasting your money on an alignment if you're just going to play with height settings afterwards
  2. #92
    Aug 2006
    Melbourne VIC
    Lowering after allignmnet will be fine.
  3. #93
    May 2012
    Well its raised and has the stock wheels on it. Its above 100mm so it should get on fine.
    I usually hit the road in some spots on the way to work (which i know how to avoid now) but yeah i couldnt see it going on.
    The guy goes to me "is that even legal??" then he continued to try and measure it.
  4. #94
    Aug 2012
    Kangaroo Valley, NSW
    The Vento
    Quote Originally Posted by Surfpig View Post
    Do we get unslammed picks?
  5. #95
    May 2012
    patience, young one.
  6. #96
    May 2012
    No caps
    With caps
    Also my front lip came, so is it the two side tabs you cut off?
  7. #97
    Apr 2012
    Milperra, N.S.W
    Re: The Vento
    This is how mine looks.
    '95 Golf 3dr... low. slow. loud.
  8. #98
    May 2012
    mine is a deep one, and it seems like its shorter... which kinda sucks i knew about this but yeah anyway.
    the camber is all back to 0 from getting the wheel alignment. so after this weekend ill see how it sits once low again, may have to tweak it.
  9. #99
    Apr 2012
    Milperra, N.S.W
    Re: The Vento
    As soon as you tweak the camber you really stuff up your alignment. Lowering and raising will make the wheels toe evenly in or out but adjusting camber is a total screw up.
    Yeah I had the deep lip before too. Didn't meet up towards the wheels. How my deep lip looked:
    Just fit it FROM the wheel to the center of the bumper.
    If yours is a cheap Chinese one it will crack lol
  10. #100
    Aug 2006
    Melbourne VIC
    It looks "so factory"
