If it is a ADY, then it should be a 1994 or a 1995 build engine, which I believe means that it is a ODBI not a ODBII ECU/interface. Not sure if ODBEleven will work with ODBI.
I have a mk3 with the ADY. I bought it with a dead motor and found another motor to put in it. I'm using the original dizzy and throttle body.
I can't get it to run, the idle hunts, it won't rev, has no torque whatsoever, I can't get it to reverse up the driveway.
I've bought an OBDeleven which I will let me clear fault codes but I can't get it to adapt the TB or anything more.
Any tips on how to make it work?
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
Can confirm, what feenix has said, I made the same mistake as OP and had to buy another ODBI compatible cable and find a copy of vag com.
Sent from my ONEPLUS A3010 using Tapatalk
Hyundai Getz (2015 -- 2017)
Golf Mk3 GL 95' (2017 - 2018 - Now)
Golf MK2 GTi 91' (2018 - Now)
I would suggest that you go back to basics. Check the valve timing, ignition timing and check for vacuum leaks.
I have checked the valve timing more than once and I'm pretty sure the distributor is timed accurately, I will check for air leaks.
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Ok, that is a bit crap as the blurb for the obd11 said it would work with this model and older vehicles too.
Yes, it may work on them, but but you don't get much of the info. Most likely you get the rpm, maybe timing.
Did you get your car started?
A longtime replying. I gave up on it for a few years but back trying again now that I've lost my A4 to the airbag fiasco.
Replaced the fuel pump and the internal tank fuel line. the pump gets 4.5 v only with key at ignition point, no extra when cranking but I can feel the relay activating. Pump does work if given 12v. fuses ok.
Has it thrown a code to cause this low voltage?
