Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Updating Gauge Cluster?
    Jan 2009
    Anglesea,victoria
    G'day guys.
    I was wondering if its possible to outfit a mk3 golf with a set of newer gauges say out of an r 32.
    Im not talking the entire insert unless thats possible also but just taking the circular pieces out and putting them into an older model.
    Attached Thumbnails Attached Thumbnails Updating Gauge Cluster?-gauges4-jpg
    Nov 2006
    Central Coast, NSW
    i don't see why it wouldn't be possible. whether it is practical is another matter...
    There is no real reason why you couldn't just use the dials from the r32 and rewire/solder them in place of the mk3 ones... it would just take alot of work to adjust them, get them to fit, calibrate them, reframe them and re-seat them in the dash...
    Dec 2006
    Kilsyth, VIC
    If all you want is the faces, it's doable, but aligning them so they read right is another question. People have put TT dashes into other cars and gotten them working, but it's no simple task.
    There are a couple of aftermarket guage face options in either black or white available which will give you a different look available on eBay. (although getting one in km/h as the major numbers can be a little more of a challenge.
    Sep 2006
    West Sydney
    Another member of the forum has these: http://www.dubdesignindustries.com/c...roducts_id=241
    Or you could design your own in photoshop and put the inserts in. I've got templates saved on my computer somewhere...
    Feb 2007
    Perth, WA
    Those look sweeeet, but I'd have to have em in green!
    Jan 2008
    the 3.5 cabrio has red lights in the cluster I believe. i may be wrong though. worth a shot though for a change from the green.
    Nov 2006
    Central Coast, NSW
    the mk4 cabrio has got blue dials i'm pretty sure.
    there is SOOOO many threads on vortex about this sort of thing though, just search.
    Dec 2006
    Kilsyth, VIC
    It's easy enough to mod up the cluster lights to be different from the stock whitish/greenish colour to anything you want.
    In the back of the cluster there are two holes for the stock bulbs:
    Under this part is a green plastic bit the light shines through:
    which is easily removed:
    Coloured LED's or a hand made different coloured plastic bit and it can be any colour you like. If your keen the bits behind the LCD's should be very similar, although much harder to "fix" if you break them. (I have a dead spare cluster I should look closer at).
    With Hot glue + a soldering iron, anything is possible, and as Rayray has said, you can make your own faces in whatever style you like and either print them yourself or get them made up by a pro printer cheap enough then just slide them on
    Apr 2008
    Quote Originally Posted by rayray086 View Post
    Any chance to see your templates. I would like to make something diggerent for my car. Thanks
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Feb 2008
    Auckland NZ
    well if you get a 1998 - 1999 (early 1999) it's possible. But R32 unit and such. I would have to say no, They have a immobiliser in them called IMMO2 (end 1999 - early 2002) then switched to IMMO3 clusters. They require to be coded to the ECU and the Key of the car. so unless you can some how remove the immobiliser parts in it. I would have to say it would be a waste.
    You would be better off as rayray086 recommended.
    Audi S4 (2001) - Imola Yellow
    Secret Project
