Results 1 to 10 of 32
Thread: Uneven height when lowered??
    Dec 2007
    Ermington, Sydney
    Question Uneven height when lowered??
    I reckon I know the answer to it but it doesn't hurt to ask anyone that might know for sure!
    Looking at the front wheels on my car, there's wheel gap on the left tyre whereas the right tyre has none. There's a difference of maybe just under an inch, and no matter how much I lower the left side it doesn't go down. Is this just because of the engine being on the other side of the engine bay??
    If there's a fix to it, or it's something small I'm missing, please tell me...I'm sick of wheel gap!
    Jan 2007
    There should not be any difference in the height from side to side, I just installed coilovers in my car and I measured the heights exactly front and back, matched them and they are identical from side to side. Looks like you may have another problem with it, broken engine mount maybe?
    Sep 2006
    West Sydney
    Lowering height is dependent on spring compression rates, so obviously the more weight you force on one corner, the lower it will go. Also, when you observe your ride height, you gotta make sure you're on smooth ground. Checking it when the car is on the road will never be accurate as roads always have a convex curvature. Best to do is park it inside a shopping centre carpark and see if there's still a different in wheel gap.
    Dec 2007
    Ermington, Sydney
    Alright I'll go have a look tonight, cheers guys.
    If the height is still uneven, does that mean my chassis is bent or something? lol...
    Mar 2009
    Wagga Wagga
    I had the same problem on my car after spinning out and hitting the kerb. It annoyed the sh*t out of me big time not having the car level!!! It took weeks before I noticed the cause of the problem.
    With the car on the hoist, look at the steering column from underneath and there is a suspension bar that crosses it. This bar (don't know what it is called) was slightly bent. I straightened it by levering it with a strong metal pipe wedged underneath the crank case and on top of the apex of the bend. It didn't come into balance straight away but after jacking the rear right wheel to change a brake caliper the next day it has been level ever since.
    It is worth checking this out on your vehicle. I understand completely how annoying it is to have the car not level!!!
    My NA 2.0L 8v Mk3 Golf is faster than my 174kw twin turbo Supra. V8 utes and over modified Skylines hate being overtaken by old Golfs
    Dec 2007
    Ermington, Sydney
    That sounds like the front swaybar...
