Originally Posted by
cicca_294
whats the deal with the timing chains?
do they need to be replaced?
how much is that usually?
i did note on how quiet the car was, does that mean anything?
anything elsE?
Timing chains like belts are prone to wearing and if they done break it'll be an expensive rebuild number. Also when finding out about the timing chain ask about the guides, these wear and are also expensive.
As said above heater core often fails and takes a while to replace or else is costly to have replaced.
I'm not on the mainland, but have accident history and got a few quotes here and there, shannons was about $600 with the car insured for $10k, which was not bad. BTW the online quotes are often far more than excessive than if you ring up.
1979 Mk1 Golf GTi
1994 Mk3 Golf VR6
