Hi Guys,
So I need a bit of assistance from the brains trust.
I just had a brand new LUK Clutch kit (pressure plate, clutch and TO bearing) fitted along with the clutch fork at the local mechanic around the corner (after my old clutch fork snapped in half). He's a good bloke and doesn't mind taking on an old euro from time to time.
The flywheel was machined at the same time.
Anyway, I have driven it about 1000 clicks since then and throughout that time the car has had an intermittent (but mroe often than not) judder when engaging the clutch under load. It improves if I use a bit more right foot but it is definitely noticeable and the judder simply seems to increase in frequency as you increase speed rather than going away.
It is also sometimes noticeable on a downshift into second when engine braking.
You can't feel any judder in the clutch pedal itself but mostly through the car.
Now I took it back to the mechanic and he happily got the guy that did the job to take it for a drive. He admitted there was a judder but seemed to think it wasn't the clutch but rather the engine mounts.
To an extent I agree as there seems to be a fair bit of play in the two engine (not tranny) mounts when you engage the clutch a little with the hand brake on, and then the whole motor judders which is obviously what is causing the car to judder.
But (yes there's a but), I have very new BFI Stealthlines holding the motor down so I can't see how these would be causing an issue?
I guess my question here is,
What is causing the judder? CLutch? Engine mounts? Something completely unrelated?
Cheers,
Max
P.S. it didnt judder with the exedy kit it had in it when the clutch fork snapped. So something has changed!
