What computer will be using to run fuel and ignition?
Heya all, as some of you may know, I own a mk3 2.slow but I want to make it a 2.turboslow. I intend to do the install myself and am sort of putting together a basket of stuff I'm going to need, I have some questions firstly, adding a fitting to the oil pan for the return line aside from the obvious drill a hole, thread/tap said hole and jam a fitting onto it, is there a specific place on the pan I should aim for so as to not hit the pickup. I'm also told I need a high-pressure oil source of some description where might I find this?
Let the hate begin.
Thanks in advance,
Rohan.
Sounds like a fun project.
I always wanted a turbo vr6 but life got in the way.
Now I'm selling the vr6 engine and all parts for a vr6 conversion for $900
Sent from my SM-A520F using Tapatalk
Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
Oil return bung higher than the oil level. Bung sits on the outside so won't be any internal clearance issues.
Feed line off the oil filter housing. 42dd sell adapter kits for this
Hyundai Getz (2015 -- 2017)
Golf Mk3 GL 95' (2017 - 2018 - Now)
Golf MK2 GTi 91' (2018 - Now)
So heres a question Im fairly sure I know the answer to buttttt has anyone ever put a t25 on an ady? Because I have the opportunity to get one cheap as chips.
Thanks in advance,
Rohan.
Sent from my ONEPLUS A3010 using Tapatalk
Hey Mate,
did this ever eventuate?
VW MK2 Golf GTI 8V 1991
VW MK3 Vento 1995 Daily Driver
Why not pop on a Toyota supercharger, just have to make up a bracket to mount it and no exhaust to worry about. I put one on the Corrado after the 2nd G-Lader blew up and it works great. You could also source a G60 ecu from O/S to drive it.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
