Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 88
Thread: trouble fitting kerscher carmona's 16x9 +15 on front HELP!!
  1. #31
    Aug 2009
    ACT
    Moar camber!!
  2. #32
    Sep 2006
    Parkinson / Brisbane
    fark they look cooooooool.........
  3. #33
    Nov 2010
    sunshine,vic
    Quote Originally Posted by KI11Z View Post
    if only i could fit them without taking the calipers off
  4. #34
    Sep 2006
    West Sydney
    195/45R16, go!
  5. #35
    Nov 2010
    sunshine,vic
    Quote Originally Posted by rayray086 View Post
    195/45R16, go!
    im thinking of putting Toyo proxes 4 / 205 40 16
  6. #36
    Apr 2012
    Milperra, N.S.W
    195/45R16, go!
    Wouldn't that make it taller than stock? Might tuck nice though....
    I had an inch of poke on mine before camber (your situation is a little different to mine). All you need is camber, that's the only way you'll get clearance. The only option for tyres is 205/40, nothing more, nothing less.
    Nice wheels
    I whore this link:
    Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator
    '95 Golf 3dr... low. slow. loud.
  7. #37
    Sep 2006
    West Sydney
    The amount of stretch would also factor into the actual rolling diameter!
  8. #38
    Apr 2012
    Milperra, N.S.W
    Check it on willtheyfit.com, unless I typed the numbers in wrong lol, they appear taller. But that was compared to my stock wheels.
  9. #39
    Sep 2009
    So how much is considered safe for grinding off carriers/calipers? Not trying to hijack the thread or anything but I just measured everything up for my RS and I need 6mm more clearance up the front to clear the brakes, would need to both grind the carrier and the caliper. Thinking I can probably do it, there will be a decent bit of metal left, but it seems pretty dodgy. I haven't bought lips for them yet so I don't have the poke problem if I go with spacers, but I'd rather not, they would sit perfectly the offset they are, just clearing the strut, meaning I can go realllly wide
  10. #40
    Aug 2009
    ACT
    Brake delete for fitmunt.
