Originally Posted by
sortofbigbj
How much smaller are the 288mm brakes? Are they much better as far as braking power is concerned? My RS dont clear my front 280mm vr6 brakes although I can probably fix them with a grinder.
But yeah, you'll have to either change brakes or grind down your calipers depending on how much clearance you need, if you really need 10mm, taking a grinder to your brakes wont be the solution. A combination of a small spacer to the front, an angle grinder to the brakes and a good pull of the gaurds might be needed. Might want to space the back out a little to keep it even aswell.
