fark they look cooooooool.........
195/45R16, go!
Wouldn't that make it taller than stock? Might tuck nice though....
I had an inch of poke on mine before camber (your situation is a little different to mine). All you need is camber, that's the only way you'll get clearance. The only option for tyres is 205/40, nothing more, nothing less.
Nice wheels
I whore this link:
Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator
'95 Golf 3dr... low. slow. loud.
The amount of stretch would also factor into the actual rolling diameter!
Check it on willtheyfit.com, unless I typed the numbers in wrong lol, they appear taller. But that was compared to my stock wheels.
So how much is considered safe for grinding off carriers/calipers? Not trying to hijack the thread or anything but I just measured everything up for my RS and I need 6mm more clearance up the front to clear the brakes, would need to both grind the carrier and the caliper. Thinking I can probably do it, there will be a decent bit of metal left, but it seems pretty dodgy. I haven't bought lips for them yet so I don't have the poke problem if I go with spacers, but I'd rather not, they would sit perfectly the offset they are, just clearing the strut, meaning I can go realllly wide![]()
