I have a manual for the 9A Passat engine here.
Crank Pulley bolt is 44ftlb plus 1/4 turn
Flywheel to crankshaft 44ftlb plus 1/4 turn, the 6 17mm ones IIRC
clutch pressure plate to crank 15ftlb, the 8 point 9mm ones
fan belt pulley is 15ft lb again
My Bentley shows a shim and washer with the auto box but neither when using a manual box.
HTH
