Results 1 to 4 of 4
Thread: ?Torque settings for 2.0L motor?
    Oakleigh VIC
    Could someone with a workshop manual look up the following settings for me please?
    Crank sprocket bolt (The big 'un in the middle)
    Crank pulley bolts
    Pressure plate to crank bolts
    flywheel to pressure plate
    Most of these are stretch bolts (New), my MK1 / Mk 2 manuals don't cover them and I'm not having much luck with Google.
    If anyone could explain the pressure plate to crank assembly that would be great too. Is there a washer in between the two, and is there a shim under the bolt heads? I'm putting a 210mm 16v pressure plate onto a formally auto 2E motor to go in a MK 1, hence the confusion.
    Any help much appreciated,
    Pete
    I have a manual for the 9A Passat engine here.
    Crank Pulley bolt is 44ftlb plus 1/4 turn
    Flywheel to crankshaft 44ftlb plus 1/4 turn, the 6 17mm ones IIRC
    clutch pressure plate to crank 15ftlb, the 8 point 9mm ones
    fan belt pulley is 15ft lb again
    My Bentley shows a shim and washer with the auto box but neither when using a manual box.
    HTH
    Oakleigh VIC
    Fantastic, Thanks muchly.
    Pete
