Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Too low?
    Mar 2014
    Bundoora, Victoria
    Too low?
    Had a slab in the back and a passenger in the back as well as someone up front.
    Rear wheels were scraping, what can I do? I'm going on a trip soon and they'll be more weight in the car...need to fix this ASAP.
    Past - '95 VW Golf MK3 VR6
    Oct 2013
    Stiffer springs or raising the ride height is about it. If thats all you had in the car then it sounds like you springs are shot anyway!
    MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
    Mar 2014
    Bundoora, Victoria
    I was looking to get some new ones anyway. It's pretty high as it is. I think stiffer springs will have to be the way to go.
    Kind of a bummer since I just got alignment and balance done, which will have to be done again once new springs are fitted?
    Recommended place to get this done?
    Roll guards. More camber. Smaller and or Skinner tyres. Less aggressive offset wheels. Smaller spacers if you are running then.
    Better shocks or firmer springs. Wind coils up.
    But really, There is no such thing as too low
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Quote Originally Posted by stefcio007 View Post
    Only the front. Rear doesn't change unless the beam has been messed with
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2014
    Bundoora, Victoria
    My tires are bigger than stock wheels, I knew this, but wasn't a problem with just me in the car. I'm not running any spacers at all.
    How much over sized? What do you have now?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2014
    Bundoora, Victoria
    Dunlop SP Sport 300E tires on VW Avus II wheels.
    Jun 2008
    melbourne
    Tyre sizes, not brand?
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by Silver dub View Post
    Is this what you are referring to? 195/65 R15 91V X2057
