Results 11 to 20 of 33
Thread: Too low?
stefcio007 Too low? 07-07-2014, 06:58 PM
a239947 Stiffer springs or raising... 07-07-2014, 07:13 PM
stefcio007 I was looking to get some new... 07-07-2014, 07:28 PM
dylan8 Only the front. Rear doesn't... 07-07-2014, 07:32 PM
dylan8 Roll guards. More camber.... 07-07-2014, 07:31 PM
stefcio007 My tires are bigger than... 07-07-2014, 07:39 PM
dylan8 How much over sized? What do... 07-07-2014, 07:44 PM
stefcio007 Dunlop SP Sport 300E tires on... 07-07-2014, 07:49 PM
Silver dub Tyre sizes, not brand? 07-07-2014, 08:03 PM
stefcio007 Is this what you are... 07-07-2014, 08:12 PM
anthony-' + '-t Mk3 should run a 195/50/15 or... 07-07-2014, 08:32 PM
stefcio007 I do have mk4 spec wheels on,... 07-07-2014, 08:37 PM
dylan8 Yeah mk4 sized rubber..... 07-07-2014, 08:36 PM
anthony-' + '-t yeah if both 15s that'll be... 07-07-2014, 09:12 PM
Water Boy Roll guards and fit 205/50/15 07-07-2014, 09:18 PM
stefcio007 They say pictures are a... 07-07-2014, 09:39 PM
rmuruga If you find what causes the... 11-07-2014, 11:45 AM
HaydEn Id say the top of tyre was... 07-07-2014, 10:27 PM
stefcio007 But no marks seems a bit... 07-07-2014, 10:30 PM
Silver dub Take the wheel off and you'll... 08-07-2014, 07:06 AM
anthony-' + '-t It's probably the tread of... 08-07-2014, 09:41 AM
stefcio007 I jacked it up and gave me... 08-07-2014, 01:04 PM
anthony-' + '-t Best option is to change... 08-07-2014, 01:06 PM
stefcio007 Isn't this something the... 08-07-2014, 01:29 PM
anthony-' + '-t Yeah it probably is. Don't... 08-07-2014, 01:31 PM
dylan8 They wouldn't know what tyres... 08-07-2014, 01:34 PM
stefcio007 ok, thanks for clearing that... 08-07-2014, 01:42 PM
Water Boy If you look on your fuel... 08-07-2014, 06:36 PM
VR6child The standard tires for VR6... 10-07-2014, 12:39 PM
VR28LT 205/50/15 is the correct size... 10-07-2014, 12:52 PM
stefcio007 Thanks everyone for the help,... 11-07-2014, 11:20 AM
stefcio007 rmuruga, I'm just running the... 11-07-2014, 11:51 AM
rmuruga Ah fair enough! 11-07-2014, 03:47 PM
    Mar 2012
    Central Coast, NSW
    Mk3 should run a 195/50/15 or similar. Sounds like you have mk4 spec wheels on
    Mar 2014
    Bundoora, Victoria
    I do have mk4 spec wheels on, I know this. Not sure if this is possible or a stupid question but can I use the tires from the stock wheels (the mk3 BBS wheels)?
    Past - '95 VW Golf MK3 VR6
    205/55/15 or 205/50/15 for a mk3 vr?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2012
    Central Coast, NSW
    yeah if both 15s that'll be fine but your current tyres are too big
    Aug 2006
    Melbourne VIC
    Mar 2014
    Bundoora, Victoria
    They say pictures are a thousand words so here's one. The thing is, I couldn't really find where the wheels were rubbing but it did sound like they were so maybe it's actually the springs that are bad? I know that if I press into the car on the rear right the spring creaks. Was like this from the start.
    Attached Thumbnails Attached Thumbnails Too low?-image-jpg
    Dec 2013
    Quote Originally Posted by stefcio007 View Post
    If you find what causes the creak, let us know haha I have the same issue when I press the rear of the car. Also, what coilovers are you running?
    Jun 2011
    Id say the top of tyre was hitting body.
    As said above. Your tyre sizes are to big, even for factory mk3.
    Mar 2014
    Bundoora, Victoria
    But no marks seems a bit strange, wouldn't there be visible marks?
    Jun 2008
    melbourne
    Take the wheel off and you'll get a better idea if it's rubbing?
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
